Hi all - I know you are bombarded with all this problems, but here is another to add to the list,
Scrolls and scroll content. do not work
nothing scrolls
I have added all the updated actions but I do not think this one was listed on the softpress site
Ok Dave
the scrolling action after I upgraded to FW6
does not work properly, It does not scroll
scroll layer, scroll content is set correctly. when i hit the scroll button - the content does not scroll
is that clear?
Meanwhile I am going back to 5.5 as all works perfectly,
i have contacted softpress
thx
You did mention ‘the scrolling action’ but weren’t specific.
I have now tried the Scroll Layer action and can see what you mean and I have added a note at ActionsForge to that effect.
But that action will need to wait for a SP fix as it is one of theirs.
There was mention of a definitive list of compatible/working actions but I don’t think that there is anything specific yet. You can refer to individual actions at ActionsForge but it does mean a lot of leg work.
