Hi.
What is the best and hopefully simplest way to optimize the website for search engine recognition?
This is all very new to me and if i’m honest a little confusing so if anyone has some good clear advice I would be very, very greatful. – James
These will give you an idea of the sorts of things that are needed and
how to get them into Freeway
I hope this helps and good luck!
On 10 May 2009, at 22:54, bigjimmy464 wrote:
Hi.
– James
There are some very useful comments made on this list for SEO,
contributed by quite a few people which I have found invaluable.
I have collated a lot of this advice into one document that I look at
frequently.
The link to the downloadable PDF is here - please don’t think this is
my work (I’m not that clever with SEO!) Or that it is 100% set in
stone as I only use it for guidelines, but it’s here if anyone wants
to look.
Also, if there are any statements made in it that people wiser than me
see as wrong or misleading, please let me know and I will change it.
and how to get them into Freeway
Hi.
greatful. – James
Thank you all very much, there is plenty here for me to read up about. I have a feeling that if I can’t suss it out from here then I may as well give up eh? LOLOL
Sometime around 15/5/09 (at 05:29 -0400) Fuzzy Z said:
Does anyone know if you index your site regularly (daily) with
google if it helps with SEO?
It doesn’t. Google only cares about content, and once it knows about
a site it won’t make any difference to keep prompting it.
Get other people to link to your site - but appropriately, not in
anything that looks like a link farm. There’s some info here: http://www.thehelpful.com/befound/
