Hello. Is there any action to make secuential images? Ill try to explain: Ive got 10 images (animated gif) that should appear one after the other, in secuence, 1,2,3,4,5,6… Is it possible?
There are plenty of free apps to help you make these.
If you just want to show a picture sequence then you could use Sequence Timer with Target show/hide http://www.deltadesign.co/examples/sequence2.html - you dont need to have the buttons I have here - it can be automatic.
I have another problem. I insert an animated gif into a graphic item, over another graphic item that is the background, but when i publish it, it become a jpg, with really bad quality, and the gif doesnt work, because it is exported like a jpg!!
I deleted the project and started again, and now it works. Forget my last message. Im sorry, but it has been desperated…
