Building a new site. I went to lunch and then came back to Freeway not responding correctly. When I click on a table, the table will be hot, however, I cannot select a cell within the table. I tried and tried until I noticed that I was not being able to select anything within the table.
I then tried to click inside a text box, again I could make the text box hot but it would not allow me to click inside the box. I even tried to do a multi-select function on multiple items and it wouldn’t respond. I even turned off my TrackPad and fired up the Mouse, same results.
I closed that site and opened a different website file. Again, it would not allow me to click within a text box to add text. It is not with just one file, it has to be with the program. I have checked my setting within Freeway and don’t see a problem.
Any idea what might have happened.
David Hamill
Freeway Pro 5.6.4
Mac OS X 10.7.4
Could be any number of things - dodgy preference file?
What happens after a restart?
Well, I had restarted it a couple of times before filing the thread. Then after posting I went back to the program and opened once more.
Of course, it worked. And, so far, it is behaving.
Thanks for the response. If it freezes again, I’ll repost.
Did you restart your Mac - not just Freeway?
Actually, only Freeway.
Gone are the days when we had to do a regular System restart - my own mac can go for weeks without one. It is actually rarely shut down.
But sometimes it is all it takes to flush the system of gremlins.
Point takien.
