I’m using the Freeway template Merge, and I’m trying to get the Contact page form to work, but it looks like Freeway is not using the Form Setup data I’m entering. I’m entering http://www.fatcow.com/scripts/formemail.bml as my Action, but when I view the source code in Safari I see thus I get a Internal Server Error when I click the Send button. Any thoughts? Thanks!
If you want to use Fat Cow’s script then you cannot use the action as it is hard wired to generate and use its own script ”FW_SendForm_contact.php”
Does your hosting plan support PHP?
Yes, I used to use a php form action before, but now i don’t see it as a page option anymore.
Page > Form Setup
No action required.
