Hey all,
I created a Send Form in Freeway and it seems to work well but there is one really annoing thing, but maybe I’m just do not understand.
There are only two default options for the sender Name, in my case I actually need more like name, surname, phone, mail, company ect.
Is there any opportunity to add more than only two specifications?
Or is there an alternative form action which can do that?
Thanks in advance
opportunity to add more than only two specifications? Or is there an alternative form action which can do that?
You can have as many fields as you like - called whatever you want and the information entered will be included in the generated email.
Try adding a field and make sure the name under the 3rd Tab in the inspector reflects its content.
Hey David,
thank you!
That was easy, it works great.
Cheers Moritz
