[Pro] Sentence spacing HELP
Hi, I have tried to find the best / easiest way to circumvent the problem HTML brings to text rendering (if I understand the situation correctly).
Anyway I have not and would like suggestions, I’m not talking about make a list but rather going to the next line, pressing return ONCE in TextEdit.
Thank you for your time.
B.
If you mean just creating a new line then Shift Reurn should work for you in FW
