I’ve got two groups of images on the one page and wnat them both to fade in and out at the same time. i’ve applied sequence timer to the page to one group but can’t apply it again to another group. any suggestions?
I had the same problem a while ago. To overcome the issue I set up multiple iFrames on the home page and then set the image transitions/sequence timers on separate pages. Its an awful way to work, but as a last resort its an option!
Hi Scott thanks, i worked on it last night and i set both groups to be the same trigger - indigo set sequence timer to indigo and it seems to be working ok now.
Each set of images had the same parameters for triggering. So don’t know if it would work if you have different timing rates on one of the groups
maybe you could test it yourself on a page, might save you time in the future
glad you’re all sorted. I had 10 different transitional groups on the same page all with different timings and different number of images per group, so I guess it was a bit more complex.
