I am having trouble with Sequence timer 60 1.0 and Sequence timer 2.8 when using Firefox 3.6.2. No problems with Safari or Explorer. I mention Sequence timer and Sequence timer 60 because I have tried using both (not at the same time).
My first target layer fades in as it should, but it does not transition to the subsequent layers.
My site is set to the following settings
HTML: HTML 4.01 Transitional
Code: More readable
Compatible: IE6/IE7
Encoding: Automatic
I have the Sequence timer set up on a master page so it will show on every page.
I also have the following actions running on some of the same pages:
Transition FX
Carousel
Advanced Fade
CSS3 corners
In addition, I have an html markup on the master page as well.
The site URL is http://www.orangeduffelbagfoundation.org
The area that should be transitioning is under “Sponsors” in the sidebar.
One last thing. My site is temporarily parked on my mobile me (Mac) server.
If you have any suggestions I would be most grateful.
Thanks.
Max
Thanks for checking that out for me David.
I will be transferring the site over to a permanent server when the site is completely built. Looks like it will work then.
Thanks again.
As Dave pointed out the issue stems from the fact that the site is
hosted within a frameset. Change the ‘Find targets’ option in the
Sequence Timer action from ‘top’ to ‘this’ and it should correct the
problem.
What’s happening is that the Sequence Timer action code is looking for
items to animate and is targeting the parent frame. Since this lives
on another server it can’t access the content and returns an error
which stops the effect dead in it’s tracks.
