Hi, I find that when I change the ‘Speed’ of the Sequence Timer it applies it not only to the time the object is shown, but also to how long between it and the next item.
ie. Speed: 5000 results in the first item showing for 5 seconds, then disappearing, then a 5 second wait until the next item shows.
Is there a way to gain control over the gaps in between, to make them a bit quicker?
Si.
