How can I do that? When I try to set these values,
FW 5 Pro Style Menu does’nt accept it …
Thanks for your help
Tom
Tom
Did you try to insert another value than the presets of FW5? To my experience that does not work indeed.
Your’re right, Atelier. I thought I could set 100% or other values…
You can set em or % in the “extended” part of the style. Create a new attribute with name = font-size and enter whatever value you desire.
There’s just one problem with this: Freeway won’t respect the sizes you put in “extended” in its preview. To get a reasonable idea of how the page will look before trying it out in the browser, you can choose the pre-set size that comes closest to your desired size and set it in the style definition as well as your “extended” em or % size. When the CSS is published, the extended size attribute will override the pre-set size.
Good tip as well. BTW, I thought for a long time already that it’s a bit odd that FW does not accept % that are not preset. Let alone that FW does not respond with a good preview. Not so very WYSIWYG I’m afraid.
