I have four large target images on a page with four small thumbnail images beside the large image that will be rollover images, very similar to the learning tutorials for
Freeway.
I’m trying to apply target image actions to each large image, but the four images are not showing up as a list of four in the Actions Palette window on the left, like they should. Each time I apply the target action, the image name lists by itself on the left column, the names of the other three images don’t show up on the left at all. This make it impossible to set up the target image numbers correctly in the Actions palette.
What am I doing wrong?
Patty W.
You only need 1 Target image action and in that you specify what actual picture files you want displayed in it on Rollover of your thumbs.
So the Target Image action can contain “links” to up to 20 images that can be triggered by different rollovers.
Thanks for your reply, but I’m still not getting anywhere.
I undid all the target actions on the four large images, then I selected the #2 image, put the target image action back on it and checked the Actions Palette. Only the #2 image shows on the left sidebar where all four are supposed to appear.
How can I place the appropriate checkmark per image number if the four images are not listing in the left sidebar?
I can’t figure out what’s going wrong.
Patty W.
Dave,
I’m building this site as XHTML transitional, would that have
any effect on the problems I’m having trying to set these targets?
Patty W.
Dave,
I figured it out after re-watching two “rollover tutorials”,
I needed to group the 4 large stacked images before applying the target action. Also, I needed to group each thumbnail rollover, then apply the action.
Now its working finally!
