[Pro] shadow frustration
I have a text box that I’d like to put a shadow behind. However, there is a background extending beyond the shadow. I should note the text box is over a pge background graphic.
Heres the link:
http://www.test.polkadotweekend.com/about.html
How do I get a “clean” shadow against the page background? Am I missing something simple? When I kill the “background” in the outside shadow dialog, I lose the shadow…
thx
-geoff
OK it was simple. I made the color of the text box “none” and made the color of the shadow background white. I guess I originally had two “backgrounds” active. getting rid of one solved the issue.
Not exactly intuitive that an active shadow requires it’s own additional background also.
-g
