I have decided to give the Shine Template a go.
It looks very nice and would suit my needs except…
The buttons on the side under NAVIGATION.
How on earth do you change the writing headings? I can do it superficially by typing it in but I can not get access to the rollover one underneath to change that too. It is very frustrating.
Any help gratefully received.
Frances
Hi Frances,
not sure if I can declare it proper but:
make sure to “show elements”! Activate this option in the side-panel.
Have a look at the master page.
Go to the homeNormalText-Element, on klick it and hit return - a cursor should now appear in the textbox - make your changes.
Repeat the step with homeHoverText and you should be done a bit quicker.
Hope this helps
… or is it called “enter” (instead of return)? Yes it is.
Sorry
I will try this - many thanks. Appreciated.
