Does anybody know how I can make in Freeway Pro a link in my page where you can see how many products there are in my shopping cart?
In the website as example it is mentioned as EMPTY.
Thanks for your reply
http://www.beyondblossoms.com
I assume that the link is not to your FW site?
What cart are you using?
David, I use the Mal’s E-Commerce Suite.
The link is to show what I mean. My webshop is not online yet.
Ronald
Here is a page that uses javascript to show the cart contents on the page using Mals.
A simple script is required and additionally a setting in your Mal’s account has to be enabled.
http://www.deltadesign.co/fw_examples/Cart-stuff/testcart.html
Thanks. That is what I mean. Where can I find or get some script like this?
Thomas4
(Thomas)
April 25, 2013, 7:37pm
6
look here:
http://www.malsforms.com/index.html
Tom
I have used mals on http://www.knowyouronions.net
even with my limited ability it is reasonably easy to sort out.
It is just a (small) one off payment - not monthly charges like some carts and it works well with FW.
still not clear for me how to do this. hope anyone has an idea where exactly I can find the right script for this
It would help if we can see your page/cart setup so that we know your starting point.
David, the page/cart is not online yet. Hope to finish it soon.
