[Pro] Shopping cart
Hello everyone
well I have a question about alternative to Mal’s shopping cart, although it is easy and convenient, it lacks in design. I would like to have my website design elements and menu on the shopping cart page. Any ideas?
Thanks for help
Carla
you can make a header to match your site as well as making all the colours
and texts match up.
In the Cart admin at Mals.
( I don’t have knowledge about alternatives to Mals)
all the best
Brian
Carla said recently:
Hello everyone
Thanks for help
Carla
As Brian mentioned you can tweak the Mals cart to suit your site by adding
header graphics and custom colors to the cart setup. If you want the
‘fully-integrated’ look you can even host the cart in an iFrame so the user
never knows the cart isn’t part of the site.
As a really great example of this have a look at this site;
http://www.cecemarie.com
Thanks so much Tim
How is this done. I have used iFrame before
C
Hi Carla,
Here’s a write up by the site designer, Richard;
https://realmac.macdock.com/realmacsoftware/2007/support/viewtopic.php?id=34575
Although he used RapidWeaver this should be achievable in Freeway with
actions. You can easily add an iframe using the iframe adtion (http://www.actionsforge.com/actions/view/99-iframe
You may need to tweak the final code with Source Code Snooper (FreewayActions.com | Source Code Snooper
) as I don’t think the Softpress E-Shop actions support the nocart
option.
On 8 Apr 2009, at 18:03, Carla wrote:
Thanks so much Tim
C
Express & Pro.
Spam.
http://www.freewayactions.com
