Is there any way I can trigger a Target show/hide layer form a text list menu within a Moo Accordion Menu. The effect I am trying to achieve is:
Moo Menu Slides open to reveal text links - on text rollover a layer appears to the side of menu.
As I recall (probably incorrectly) you can trigger html boxes to slide from text links as well as from objects. So you should be able to trigger another box to the right of your menu with a text rollover.
I like the accordion action a lot and have combined it with CSS menu action to get all sorts of sub-menu text and layer link combos.
Have a look at http://www.ldtiles.co.nz/porcelain.html
It may not be exactly what you have in mind but it probably can be bodged to achieve something that works!
Actually, I had to bodge a bit to get it to this point…
I converted the heading text to graphics because they came thru with some inexplicable rollover characteristics which I couldn’t get rid of otherwise.
I have also had to add an invisible box below the accordion text to reveal the amount of picture required.
No doubt Walt or Dave know better ways to achieve the same but this works for now.
The downside of having the title as a graphic is that a search engine can no longer find them…
