Hey all love the Showcase option in 5.5, but what I would like to do is switch out the buttons so every website is not the same look and white does not go with every design… Thanks for any ideas
Hi Carla,
Here’s a quick and dirty guide to adding your own controls. When I get time I’ll clean it up and add an article to the Softpress KnowledgeBase.
Download a copy of the controls.png file that the Action uses to display the buttons. You should be able to find a copy of this in your site’s Resources folder.
Open the file in Photoshop (or similar) and you’ll see all of the controls (plus one that didn’t get used) in two rows of 4 icons.
Each icon is roughly 26 pixels square so for the sake of keeping things simple we’ll keep to this size for our new buttons.
Using the controls.png file as a template create your new buttons and save the resulting image as another 24-bit png with transparency. I called mine ‘steel.png’
Back in Freeway attach the Upload Stuff or Upload Extra Resources Action (see below for links) to your showcase page
Select your new controls png file and choose to upload it to the same folder as the HTML file
Go to Page > HTML Markup… and select 'Before ’ from the Insert menu
Paste the following code in the dialog, change the file name to match the one you chose in step 4 and click OK;
I tried this - and tested with your steel.png - uploaded stuff into resource folder. Inserted markup in proper place and no controls at all show up… do I delete the old control.png
for this to work
As a follow up to this I’ve created a simple Action that streamlines the whole process of updating the Showcase controls image. Showcase Extras[1] is a page Action that allows you to choose one of the 13 pre-defined button styles within the Action of select your own and use this in both image galleries and slideshows.
I’ve also added the ability to add images as watermarks to the gallery images so you can easily add copyright or contact details to your images in one easy step.
If anyone fancies designing their own set of controls to use with the Action just send me your PNG file and I’ll add it to the project.
Hi Carla,
Hi Carla,
The Action is a page based item so should be applied to the Showcase page by using the Page > Actions > Showcase Extras menu option. The settings for the Action can be found in the Actions palette (Window > Actions).
On 10 Mar 2011, at 23:59, Carla wrote:
Ok I have looked around and after installing the Showcase ectras I can not seem to find it oy
I am using the showcase extras action. I can set the button to any of your presets and to any custom ones I have created. It works fine in Preview and in the browsers preview. If I close Freeway and reopen it, the button defaults to Candy-Black all the time. Looking at the HTML source, it is fine when I close the freeway file. As soon as I reopen the file in freeway it rewrites it to the candy-black.png file.
Hi Paul,
Thanks for bringing my attention to this. I’ve just uploaded version 1.1 of the Action that hopefully fixes the issue you were seeing with the button style getting reset between saves. You can download the updated action at ActionsForge; http://actionsforge.com/actions/view/226-showcase-extras
