Is it possible to turn off the graphic thumbnail arrows?
The layout I have is the larger photo on the left with 3 thumbnails visible on the right. The thumbnail arrows are at the top and bottom of the thumbnails. I only have a total of 3 photos so when you click on the arrows the thumbnails just loop to the same 3 thumbnails. I would like to turn off those arrows if possible.
You can hide the arrows (controls) in the window that opens for the slideshow using the setting in the Action palette near the bottom under Layout
Controls:Visible Controls:Hidden or Controls:Autohide
But you cant for the thumbnail advancer.
Instead you could use the Showcase Extras action on your page (available from ActionsForge) and use it to select your own image file for your controls. If you then pick a blank image no controls will show - but you will still get a link on hover over the spot where the controls would be.
