I have a page which used to display music manuscript via a Sibelius Scorch plug-in. This plug-in is still maintained by Sibelius, but my manuscript no longer shows up.
Has Freeway lost support for Scorch and is there a viable alternative?
Many thanks.
Didn’t know it ever had specific support for it.
Can you post a link to an example page and we can have a look to see why it doesn’t work.
I am assuming the Scorch code was added via Markup?
Thanks for the reply, David. The page in question is here:
http://www.graemetaylor.com/transcriptions.html
Looking at the Sibelius web site Scorch appears to be a Browser plug-in?!
What OS are you using as the last note about compatibility doesn’t mention any OS greater than OSX.7 and is dated nearly 18 months ago.
Sibelius Scorch plug-in compatibility
Support for the web browser plugin: Scorch
Last Updated : August 13, 2013
This probably has nothing to do with FW.
Does it work on other sites you visit? Examples?
Sorry! I am using OS X 10.10
I will check other sites - it certainly used to work!
Once you have found one that works then post a link to it and we can compare them.
Not sure if this is relevant or not:
If you wish to distribute Sibelius .sib score files without the HTML wrapper, for others to play using Scorch, then you can export the score from Sibelius 7 into Sibelius 6 .sib score format.
Thank you - more later…
GT
