Not sure if Tim is about just now. I contacted him a few days ago with a problem I’m having with this action and links not showing up correctly and have yet to hear back from him.
Hi Erik,
Apologies for the delay in getting back to you on this.
What version of the Action are you using?
The latest version will allow you to set the background colour of the button to a solid colour, radial or linear blend, or simply keep it transparent (a ghost button); http://www.freewaystyle.com/-simple-buttons/
You should be able to set the background colour to ‘none’ and the Action will set the button to use a transparent background. If this isn’t working for you drop me an email and I’ll send you a copy of the latest version of the Action.
On 2 Sep 2015, at 15:33, Erik wrote:
Does somebody now if it is possible to give the background color of a simple button (simple buttons action) no colour.
