I have almost got the simple site search action working.
So far it has been easy to set up with very impressive results, it’s worth the upgrade fee alone !
However, I am having some teething problems.
I applied the search box to a master page which in turn added it to all the correct pages. The problem is that the search box works on some pages but is totally unresponsive on others.
If you take a look at www. wet rooms direct dot net
The site search box is in the left column under the category menu.
On the home page the search box works. If you go to the page for Grab Rails, the search box is unresponsive?
