I have added the Simple Site Search action to the search field and the Submit value to a magnifying glass.
I made a new page for the results to display in and the action box that displays the search results (changed colors, results per page etc( and added Simple Site Search action to the folder.
When I preview thought nothing displays in the space where the results should appear.
Any thoughts?
Thanks to anyone who takes the time
Thank you DeltaDave and DTP2 for your help but I’m still not getting anywhere…
I think I have followed the steps and in the page I’ve created for the results to show although they do (the action default that I can then modify, link color, font etc) while in Freeway when I try searching for something I’m taken to the correct page but no search results appear.
Is there a conflict with some other action I should be looking out for? Something else I’m missing?
Link to site is: www.advocati.gr/greek/law_drafting.html
Ok thanks to you both got it to work… there seems to be some conflict with another html item on my page… When I had it as “Search Results” (two words) then the results wouldn’t show… after a lot of frustration I figured that by only writing “Results” instead, the results would show… maybe that is obvious to others but it had me banging my head.
Thanks again,
Alex
