I want to include both a Simple Site Search and the PayPal Button on my Master Page. I understand that it is necessary to use the Multiple Form Action, which I have installed, but I am unclear as to how to use this to make both forms work on the same page? Thanks!
http://seaquester.org
This problem comes up quite frequently and has been discussed quite recently http://freewaytalk.net/thread/view/141208
and also here http://freewaytalk.net/thread/view/140686
Thanks, David, but this is all far more complex than I was hoping for. A simple tutorial would sure be great. I’ll see if I can work my way through this.
Kevin
The Key point from the second thread is this:
You must use the Multiple Form Action to insulate the search form from the rest of your page. Apply the No Form Action to the page, and apply the Multiple Form Action to each of your forms (select a common parent of all of the form elements, perhaps a table if you have followed the conventional wisdom and placed all of your form elements and their labels in a table).
