Keep getting ‘Gallery XML Not Found’
So…
I’ve made a folder on my desktop.
Dropped the simpleviewer.swf file on my page.
Used transmit to upload the images, score and thumbs folders, and gallery.xml to the same level as the page.
What am I doing wrong?
I have a simpleviewer example at http://www.deltadesign.co/sv/index.html but that isn’t how I did it.
But there is more than one way to skin a cat!
My method was to Insert>Markup Item and paste in the code
<!--START SIMPLEVIEWER EMBED.-->
<script type="text/javascript" src="svcore/js/simpleviewer.js"></script>
simpleviewer.ready(function () {
simpleviewer.load("sv-container", "100%", "100%", "222222", true);
</script>
<div id="sv-container"></div>
<!-- END SIMPLEVIEWER EMBED -->
Make sure that the paths were correct. Then upload the various files/folders ie images, thumbs, svcore, gallery.xml
But it was a while ago
I’ve done this and not it’s blank
Online example?
