Hi, I wonder if anyone could suggest a correct setting here. I have a site which appears correctly on all platforms, except the iPhone, where the footer bar overlaps text and certain elements are being moved around. Everything is contained within the page setup, but I am unsure as to what setting I should use under Mobile setting within the inspector. Is there a standard set that should be applied to avoid this?
http://www.covarrdesign.com/galini/index.html
not sure with this (as ever) but set the position of the footer (m1) to bottom 0 rather top 1388px using the inspector (greying out the top should be enough).
There isn’t anything in there that will help you.
Is it 6 Pro you are using?
Unfortunately its not just your index page where you have overlap issues - I am seeing it to a certain extent on all pages.
The one foolproof solution - an inline layout. Or move to 7 and use the responsive features.
