[Pro] Site Meters
Does anyone know of a good, free site counter tool that I can easily put onto a freeway site. By site meter I mean the tools on your site that keeps track of how many visitors you have.
Hi Nate
I have used this site successfully:
http://www.free-counters.co.uk/
you can view my counter at www.creativeline.co.uk
Regards
Kevin
If you don’t want the world to see your traffic numbers, you should
look at FreeCounter. Since 2002, the premier Freeway-centric counter
solution. http://freewaypro.com/counter2
On Sep 13, 2011, at 12:02 PM, Kevin McElligott wrote:
Hi Nate
Regards
Kevin
Sounds great, thank you very much.
Walter,
Hi, got a moment? I can’t seem to find any instructions on using the RSS feature of Free Counter 2. I am also unclear what to put in place of ‘$myHeading’ if and when using the ‘include php variable for page title’ check box.
Thank you for your time.
Frank H.
To subscribe to the RSS feed, you simply click on the RSS button that appears at the right side of your location field (Safari) when you’re on the actual page you want to follow by RSS.
As far as the PHP variable, if you have set up $page_title in your own PHP code, and that’s what you called your title variable, then that’s what you enter in the Action. But if you’re not using PHP to populate the Freeway-designed layout for you site with dynamic content, then you don’t need to worry about that section at all.
On Sep 15, 2011, at 10:35 PM, Frank H wrote:
Walter,
Frank H.
Thanks!
Frank H.
The RSS is so cool! I very little experience with it. Now it gets delivered to email! Very slick.
Frank H.
