Saw this site http://www.mydressboutique.com/ on freeway’s list of sites made in freeway. Was wondering if anyone knows what action is used to produce the motion when mousing over the photos.
Thanks!
It’s hand-coded, and depends on jQuery, but there’s no credit given for the script. It is very nice. You might try something with Transition FX in Freeway to do something similar.
Thanks!
I’ve tried using the transition fx and I can’t ever get it to work properly. Is there a good resource to utilize for help? The freeway help guide is pretty vague.
