Hi
The above site rebuilds completely when I 'Publish site" even if I only change an item on one page. It even rebuilds if nothing has been changed
If I “view in a Browser” it rebuilds.
If I ‘Save’ it says “saving graphic” even if nothing has changed.
I tried saving to a new Site Folder as mentioned in another thread, but it didn’t help.
Not sure what version of FW you are using, however i had a similar issue a while back and it turned out to be an issue with FWpro 6.x.x and the Site Mapper Action.
Remove the Site Mapper Action and see if you have the same issue?
It’s only a new site - I haven’t applied Site Mapper action as yet.
Thanks for your input though.
Paul
On 20/04/2013, at 5:58 PM, ejw email@hidden wrote:
Paul,
Something in my memory is making me think that it’s the Navigation Popup. To test this, try the following. Quit Freeway, and in Finder, locate and duplicate the Freeway document for this site. Open the duplicate, and change the Site Folder in the Document Setup dialog to a new blank folder. Finally, remove the Navigation Popup from this duplicate and publish twice. See what happens on the second try.
On Apr 20, 2013, at 5:20 AM, Swan Photographics wrote:
Hi David
Actions :
Meta Plus 1.5.1
Freecounter2 -page 2.4.0
CSS Menus 2.1.12
Navigation Popup Default 2.4
Box sizing 0.2
Remove Dimensions 0.5.1
PHP EasiForm 1.49
PHP Easiform Elements 1.23b
GoogleMaps 2.1.1
The Edit>Resourses Resample had no effect.
I can live with the fact that its annoying, as long as it’s not going to be detrimental to my site own the track.
Paul
What actions are you using as some of them do require a rebuild every time to ensure that they do their stuff.
Actions like Link to Page (I think) have this effect.
Another thing that you can try is to Edit>Resources and use the Resample All button down the bottom left.
Followed your instructions, but the issue still prevails.
I’m also using Exhibeo action 1.03 (just updated from 1.0 today) and Exhibeo Extras actions
I’m using backdraft 1.1 and made some Master Pages to work with and thought perhaps I did something wrong, and have spent hours and hours removing/trying/replacing everything I can think of.
In frustration I launched a new Backdraft site. The issue is there as well, even without any changes.
Is anyone else using the Backdraft Template having this issue?
Paul
Hi David
Actions :
Meta Plus 1.5.1
CSS Menus 2.1.12
Box sizing 0.2
PHP EasiForm 1.49
GoogleMaps 2.1.1
Paul
That’s exactly what I’m doing now. I think I’ve found the culprit/s. Possibly the contact form page with the Google map, and/or the sample page, and/or image/s included with the sample layout as examples in the template layout.
Removing some of these has stopped the rebuilding. Just have to narrow it down now.
Paul
Strip it back to the bare bones - this may be a template specific issue and it is worth removing stuff until you find the root cause.
I can’t resolve the problem, even after-
deleting all examples, images and links from the existing template.
building it again from scratch without the Examples and images
opening a blank site and inserting the template code ‘Before Head’ before adding elements
I feel that issue may be something to do with my Master Pages. Making two child copies of my Master page (with in-line elements) the issue is not there. When I made 10 copies of the Master page, the issue resurfaced.
Paul
On 22/04/2013, at 8:27 AM, Swan Photographics email@hidden wrote:
Hi David
ESP:-)
Paul
