I’m just working my way through Freeway Pro trial version. I used to work with Frontpage before I bought my iMac a month ago.
One thing I haven’t figured out on Freeway yet is the web structure. Our current website, that I will recreate in Freeway, has parent and child pages and sometimes another child page underneath. I’d like to keep the path to the pages on the web the same (e.g. www.mysite.ca/product/product1/product_details).
How can I do this in Freeway 5 Pro?
Using the Site pane (left panel in the Freeway interface) you may
create a new folder for each product. Then simply create a new page
inside each of these product folders for the basic product details,
and as many other pages as you need, each titled the way you like. If
you really need to get fancy, you can nest folders up to any level.
As long as there is a page inside each folder that has the filename
index.html (if you’re on an Apache server or anything pretending to be
one – other servers have different defaults, and your hosting
provider can tell you definitively what your “magic” index page should
be named) then someone navigating to that folder name: http://example.org/products/product1/
will see the index page inside that folder. And if they then tack on
the details page filename, they will see that: http://example.org/products/product1/details.html
On Apr 26, 2009, at 2:36 PM, MK wrote:
Hi there,
