[Pro] Site Suggestions
I have this site Iam trying to make http://sunshineambassadors-dance.org/ and I am having a hard time designing it. All the information in the site is there I just dont know what to do with it. I am in no way a professional and I do not know what I am doing, so any suggestions would be great.
One of the first things I would suggest is that you work on standardising your text styles - at the moment you do not have a consistent typeface site-wide nor are all your headers, sub headings etc the same.
Look at it graphically as well - what is the image that you want to represent? Is there a logo, are their pictures, what colours should I be using.
Once you have a better idea of these it will help you to formulate the structure.
And if you can share some of that with us we can guide you a bit better.
Another option is not to start from scratch at all. Have you looked at the templates that come with and are available for FW - is there something there that could be tweaked to reflect the colours etc you want to use.
Ok the problem with the logo is I have no Idea how you could put that on the
site anywhere. I put the freeway file and the logo in the top right corner
of the home page so you can see it.
using.
structure.
List Options | FreewayTalk
I have no Idea how you could put that on the site anywhere
You can drag and drop from the finder onto the FW page
I ment that when you have the picture on there I can’t find a way to
incorporate it like a normal logo.
Sorry, what do you mean by "incorporate it like a normal logo? Do you
mean layer it over another graphic? Freeway is capable of reading
almost any graphic format that Illustrator and Photoshop can save, and
it can composite images together with full support for alpha channels
and transparency. Can you give an example – even on someone else’s
site – of what you’re after?
Ok. If you look at the logo you will probably know what I’m talking about.
It is not a normal logo, like the one for freeway it’s too big in the since
that if you put it on the page its too big. If you shrink it then you can’t
even see it. I’m thinking that I need to find another logo to use.
You know that Freeway lets you resize an image to any degree you like,
right? Just click once on the box so the handles are showing, then
hold down the shift and command keys to constrain proportions and drag
the bottom-right corner. Down and to the right makes it larger, and up
and to the left makes it smaller. Any percentage you like.
about.
the since
you can’t
and
Yes I know. Just look at the file, you can download it on the home page, top
right corner. If you can make that logo look good in the top please be my
guest.
about.
the since
you can’t
and
The problem with the logo is that there isn’t enough contrast between the bg yellow and the colour of the sun.
http://www.deltadesign.co/examples/sunshine.html
I would use the sun and its rays on a transparent bg and enhance the colour of the rays a bit - this would give you better flexibility over what colour bg to use.
Yes I defiantly agree with that. I will try to make my site look more like
that. Thank you so much.
colour bg to use.
Would you mind putting the freeway file you used for that page up so I can
download it. I would appreciate it. I love that design that you used.
bg to use.
I can see what you mean. I don’t think you can resize that without
losing everything, it’s just too low contrast to work with. I just did
a quickie deconstruction of the logo in Photoshop, here’s where I
ended up after 15 minutes: Untitled
page, top
be my
guest.
like,
drag
up
about.
the since
you can’t
you
and
channels
way to
I can not acces your link. But I know what you mean with the logo, if you go
to the link that DeltaDave had earlier he makes my bad page design look
really good.
On Wed, Mar 9, 2011 at 9:11 PM, Walter Lee Davis email@hidden wrote:
I can see what you mean. I don’t think you can resize that without losing
everything, it’s just too low contrast to work with. I just did a quickie
deconstruction of the logo in Photoshop, here’s where I ended up after 15
minutes: Untitled
top
guest.
about.
the since
you can’t
and
Oh, sorry, I had the wrong files in that folder. Try again. Great
minds think alike, I think I was channelling Dave.
if you go
look
really good.
losing
quickie
after 15
minutes: Untitled
page,
top
please be my
guest.
like,
drag
and up
about.
the since
you can’t
Do you
save,
and
channels
else’s
way to
Yes I like this design too. Can you and dave please send me your freeway
files for those so I can try to make something like daves design with your
logo, and some color adjustments.
if you go
look
really good.
losing
quickie
after 15
minutes: Untitled
page,
top
please be my
guest.
like,
drag
and up
about.
the since
you can’t
Do you
save,
and
channels
else’s
way to
Yes Walter’s version of the Logo is what I had envisaged but probably worth having a version that works on a light background as well as a dark one.
I will put a link to the FW file up later at the same address as the example.
Ok thank you
one.
example.
Hi Nate you can download the file http://www.deltadesign.co/examples/sunshine.html
