On the home page of the website I have a simple slide show of twelve images created using the sequence timer and target images. My problem is that when the website is loaded with a slow internet connection, there is nothing there to let you know that the slide show is coming. Ideally I would have the first image be on the page while the rest of the slide show is loading or just a “loading” symbol. Any suggestions? You can take a look at the site here - http://www.matthewgraypalmer.com/test/
Thank you in advance for your time. I have been referencing the forum a lot through this process!
-Danielle
