Could someone have a look at this page and tell me why the slideshow doesn’t show in Chrome. Works in safari and explorer. http://sbsd.info Thanks in advance, hope it’s an easy fix!
I can see the errors generated in Safari as the Sequence Timer Action runs. I suspect Chrome is failing because the Action is looking into an iframe that was created by the AddThis Action which, in turn, throws an error. Safari just gets on with things but I guess Chrome is set to just stop and not go any further.
First of all try changing the ‘Find targets’ setting on the Sequence Timer Action to ‘this’ and see if that helps. It should but if it doesn’t then you may need to pull the AddThis content until you can find a suitable workaround.
