On 12 Jul 2010, 2:12 pm, Paul wrote:
Hi Pete,
yes been using Carousel (chur to Walter)… though wanting it not to slide/glide through just fade in/fade out as per the example.On 12 Jul 2010, 12:42 pm, Pete wrote:
Hey Paul,
If you like the look of this slide on the apple site http://www.apple.com/iphone/
Galleria has a similar version here http://galleria.aino.se/media/galleria/demos/dots-01.html
View the page source, it’s an easy setup but it is jquery so as you know there are possibilities for conflicts with other scripts you may already be using in Freeway ?.
Other Galleria options here http://galleria.aino.se/Regards,
Pete
Hi Pete,
I have had a look at the Galleria version on http://galleria.aino.se/media/galleria/demos/dots-01.html and yes although the setup does look pretty simple within the source code, I’m still having difficulties implementing the ‘dots’ style theme in FW!!!?
Can you please help me with a brief bulleted list of simple instructions Pete of how to proceed after you download the source files from Github.??
Any help would be most appreciated Pete unless Paul you have had success in making this happen in FW?
Many thanks
Worm
