I downloaded this sample about two years ago from http://www.freewaystyle.com/ and I would like to use it on 3 different pages in multiples of 5 in two rows, in a new site that I am building. The downloaded sample works perfectly but there is no description on how to do it. I tried to copy the whole thing -all elements - to the new site but is not working. Also I can’t find any action or anything else that will trigger the captions.
I would appreciate any help or input on how to make this work.
I noticed that version 6 has changed a lot from the version 5 that I use to know, and I am having problems with trying to find answers on Freeway Talk. All samples available are given for older versions or the links are no longer available. A revision of Freeway Talk and a real version 6 book with samples should be made available for the few people that want or need to buy it.
Have a look in the Styles (Edit>Styles) in both documents, (the original and yours) then on yours click on the cog and import styles. Navigate to the original document and drag and drop the 5 there into your styles (probably called "sheet one)
Hi Dan,
I’ve added some instructions to the page that should help you get started in moving the panels to your own Freeway projects; http://www.freewaystyle.com/sliding-captions
THANK YOU BOTH, SO MUCH for taking the time to answer my questions and give me the instructions on how to finish my project. Can’t wait to try it and make it work.
