I asked the question earlier and what i want to know now, is that now that i have the action i want (Protaculous) Carousel. Do i need to redo my layout/page to look like this website http://www.sunshinedoorsspecialists.com/home.html
Below is what my site looks like not finished yet http://www.csdesignmtl.com
Yes if you want to use Carousel in this way to essentially create a 1 page site.
How it works is that you create your ‘panes’ and the content from your current individual pages will be contained within the relevant ‘pane’
It generally works best with a limited amount of content in each pane so you might want to trim it with links on to the expanded version on a page of its own.
Can I also mention that the ‘Splash Page’ is considered old hat these days as a page like that http://www.csdesignmtl.com/ has no real ‘content’ ie no SEO value at all!
You would be far better to have your visitors arrive at an opening page that has some meaning and save them having to click through.
