For some reason all of a sudden slim box pop ups are not displaying images. When I preview the site on my computer from the same location it was created they work fine. If I copy, archive or save as template file to another drive and open the site none of the pop up windows display an image when previewed. Any ideas what could be blocking slimbox from displaying the images. I have built many other sites this way without any issues.
www.delmano.com/What’sAvailable
Please note - you should NOT use any other characters in file/folder names other than the Alphanumerics (a-z, A-Z, 0-9) and _ underscores and -hyphens.
Other punctuation is not good. That is why your link is bad.
Please note furthermore, that frames are the most ugly way to build pages. By lookin’ through the source code (as far as I could) I furthermore doubt, that this artwork is done by Freeway. And if - please note, that you have trillions of “Unsafe JavaScript attempt to access frame with URL”.
DeltaDave,
You are correct. My bad I should have picked up on that sooner, Now that the folder reads WhatsAvailable on the site everything works as it should. My development folder was labeled differently which is why it worked for me every time, When I renamed it “What’s Available” it failed every time on my computer as well.
