billyk
#1
Want to use a smooth Scroll on my page but I have a WOW slider on it and there seems to be a conflict with the WOW javascript in the .
I tried iframe from but can’t get the Slider to resize. I’m using Backdraft.
Billy
actionsdev mailing list
If you want to stick with Wow then you should probably find yourself a jQuery smooth scroll plug-in.
waltd
(Walter Davis)
#3
Or put WOW in an iframe.
You could try the following code in Page>Html Markup in the before slot after your reference to the jquery library.
<script>
$(function() {
$('a[href*=#]:not([href=#])').click(function() {
if (location.pathname.replace(/^//,'') == this.pathname.replace(/^//,'') && location.hostname == this.hostname) {
var target = $(this.hash);
target = target.length ? target : $('[name=' + this.hash.slice(1) +']');
if (target.length) {
$('html,body').animate({
scrollTop: target.offset().top
}, 1000);
return false;
</script>
But this is a bit of a guess without seeing your page and how your links are formed. If they are just anchors you should be fine.
