I have used the type weights (700 and 400) used by Google, as the font has seven weights (100, 200, etc.). Please advise on how to correctly spec type weights. Freeway seems to recognize it and handle it as intended.
As to the extra colon, I think it came from adding a colon at the end of the font set specification. I removed it.
I can’t find the line of code to which you refer on the page so I assume it is in the site’s Style Sheet. How to I view that code using the Developer menu in Safari?
Refreshing your page, Walter, in Safari 8.0.4, I am now getting what DeltaDave shows. Did you change something in that code? I replaced the semicolon in the font set, to see if my removal of it provoked this, to no avail.
I cloned your page, and I haven’t updated my clone, so that’s what you’re seeing. As to the type weight, the point that Dave was making was that you used the code type-weight, when the actual code is font-weight. So change that, and your page should be good.
I see the problem with my example now – you took down the original test page, and with it went all of the linked CSS. I didn’t cache that here, I just put a base href at the top of my page to point back to your stylesheet. So my example is now lost to the ages.
I see the problem with my example now — you took down the original test page, and with it went all of the linked CSS. I didn’t cache that here, I just put a base href at the top of my page to point back to your stylesheet. So my example is now lost to the ages.
Didn’t intend to obliterate your excellent example! I have now put back up the page, with the unicode triangles removed, fixes to the double semicolon and the font-weight specification, and links to other pages in the site build removed.
This doesn’t seem to be having any impact on your page though: it continues to show the previous version of the page.
