[Pro] Some Questions
I have downloaded the free trial & having a go at it.
When adding in Images, does the software automatically make them smaller file sizes for faster loading?
After the site is on the internet, where can I access the HTML code to put in meta tags?
Thank You
Once imported, you can go to the Inspector panel and click the third tab - this is where you can see / adjust the output of your images. JPEG 75% is set by default, but you can raise that, or change to another format, PNG for example.
Once you have uploaded (or before), you can go to Page > Meta Tags, and you can enter your information there. i.e.
Click New…
Value: Title of your page
Then re-upload.
See these pages for further help in meta tags and freeway:
http://www.thehelpful.com/befound/index.html
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
Thank You
There is also a pay-for screencast found here:
http://www.danjasker.com/store/screencasts/details/search-engine-optimization-seo-101/
Oops, at least my link will cover how to insert the META tags plus some other SEO topics.
I am VERY impressed with this software.
My plan is to purchase in 3-5 days.
If I start putting together a site with the trial version, what changes after I buy?
I can start start a site now & save it & use it after I buy this software???
What I mean is that I do not even see where I will put in a serial number to authenticate my copy.
Thank You for your patience & your time to read & reply.
Bill
After you buy then anything that you have created already will be fine for you.
The Full release version will be available soon and at that point you will be able to serialise it.
Ok so then the final release is not even out yet?
Yep, it will be a new application though, the preview is just the preview that can’t ever be serialised.
HANG ON A SEC, lol
What if the final does not get released before my free trial runs out?
Am I just out of luck & have no working software?
Obviously the forum is faster than support emails.
I am trying to discuss what is a qualified discounted person.
Do I have the option to IM someone here?
I am not sure I should post it in open forum.
Thank You
I would be willing to assume that they will release a final 5.5 before the trial runs out. I’m not on the SP team or anything, but it would make sense for them to do so.
