Well that didn’t take long.
http://www.deltadesign.co/fw_examples/walts_scripts/tablekit.html
Draw Table and populate with data, apply 2 actions TableKit and Table Helper.
Add a Class name to the table of ‘sortable’.
Add Class names of the sorting criteria to the appropriate column header ie ‘date-au’, ‘number’ and ‘text’
waltd
(Walter Davis)
December 31, 2012, 1:00am
22
TableKit does the classname for the table and the TableKit Header does the various column header classes. All you need to do is draw the table, apply TableKit to it (no more need for TableHelper) and you’re done. If you have a sort that’s different than the default text, you apply TableKit Helper to that header. Done, no extra anything needed.
Thanks for the clarification - obviously the way I implemented it duplicated the effort.
All clear now.
