I have used Source Code Snooper for one of my websites and works fine BUT I am trying to put a You tube video on another site but Source Code is not an option on menu. So I tried to download it but it is no longer avaialbel. Does anyone know where I can find it.
Sometime around 29/3/09 (at 08:44 -0400) Carla said:
Hello everyone
Don’t use Source Code Snooper! That is an impressive and powerful
tool, but it should be used as an absolute last resort - and with
care.
Instead, you can use the built-in Freeway feature for adding custom
markup code to a layout: go to the menubar and choose Insert > Markup
Item. Paste your code in the window that opens, click OK, and size
and position the ‘markup’ object that is now in your page.
ok here is what I need, I have used the You Tube action, but I use Source code snooper on the page so the You Tube video I inserted stands alone. I do not want the related videos to appear. that is the only reason I use the SCS.
I realize that if I make changes on the page I have to undo SCS, make changes and redo code. But this is not a problem
Hi Carla,
There appeared to a problem with the download counter I was using on
the FreewayAction.com site and the link couldn’t locate the correct
action to download. I’ve fixed this now and the action should be
available again.
On 29 Mar 2009, at 05:44, Carla wrote:
Hello everyone
And why it is website specific…
Thanks ever so!
Express & Pro.
Spam.
Any advice?
I am finally getting caught up on this list, so this reply is quite
late but…
I am not sure why you are not using the Embed links provided by Youtube.
Click on the snowflake to the right of the Embed field and then select
your options.
Now, select the Embed code and, like Keith said, paste it into an FW
HTMLMarkup item.
