Hi - I would like to decrease the distance between my headers and body copy but using the space after stye does not work - I presume because the body is on a 22px leading… so anything less for space after would not work right?
Is there a way to do this?
Thanks!
http://www.easthalldesign.com/everglades/
Have you tried setting Space Before to 0 on the body text?
No Ill try now thanks
Just tried - no difference?
Are you seeing it in all browsers - I ask because Safari user agent stylesheet adds
margin-bottom: 0.67em;
Might be worth duplicating your H1 style (H1.nomargin) and adding in the extended section
margin-bottom: 0em !important;
Yes all browsers are the same webkits and IE are my main concerns…
Ill try the above
That seems to work!
used 5px and its perfect on all browsers.
Cheers!
You could probably achieve a similar effect using line-height 50% on the H1 in conjunction with the space before of 0 on the body text.
As long as you have a solution.
Yes thanks
J
