when typing and then hit the return button. it puts too much space between the lines. any suggestions to create less space between lines?
Press: Shift - Return
That was easy enough. Thank you so much. I love Freeway Pro but just know enough to get myself in trouble. Guess everybody has to start somewhere
You can alter the space between paragraphs by selecting the text and using Style>Space Before or Style>Space After
Under the “Style” menu, set both the “Space Before” and “Space After” values to zero. (Translation: “Set the space before this paragraph to zero AND set the space after this paragraph to zero.”) This will eliminate the extra line spacing between paragraphs.
Rick
