If I have a link which opens a new window on TOP.
Can that new window have a link that then opens a 2nd new window on top?
I have the first window opening up using Spawn new window and tried the same with 2nd but did not seem to work. Instead the 2nd new window replaces the first on-top window.
To replace a window with another, just make sure they have the same JavaScript Name set in the Spawn New Window Action interface. If you call one window foo and another bar, they won’t replace one another. If you call them both foo, then a click on one or the other trigger element will put the selected content into the one and only ‘foo’ window. If you set different dimensions for each trigger through the SNW interface, then the one and only window will be resized to suit those preferences.
On May 20, 2012, at 11:50 AM, Hoffman wrote:
Hi,
Page 1 has a graphic with an internal hyperlink that opens up another site page on top using SNW (we’ll call this page #2).
On page #2 which opens up on top of page #1 and much smaller, is text and a graphic. That graphic is internally hyperlinked to another small site page (we’ll call this page #3).
Ideally I want to have page #3 open up small and On TOP of page #2, but when I use SNW for it, it replaces page #2 all the time. I checked the javascript names in the SNW settings and they are different and of course the site page names are different.
