Well, no. But if it’s going in a page which also has some of Freeway’s built in transition effects or any of my Scripty Actions, then it’s going to fail to work. It’s based on jQuery, so it’s not compatible.
On Apr 3, 2012, at 2:48 PM, Peter Walsh wrote:
Hi,
anyone had any experience of speakker audio player?
Sign up for SoundCloud. They have a very nice player that you can embed in an iframe (and there’s an Action for making those). The neat thing about it is the player is responsive – if you want a tiny widget, just make the iframe smaller, if you want a huge waveform and all that, you make it as large as you like.
On Apr 18, 2012, at 3:54 PM, Peter Walsh wrote:
thanks Walter, do you know of another solution to embed an audio player that would work with freeway?
