[Pro] Special Characters
Hello,
Just to preface, I am a newbie. I am learning Freeway, and thanks to folks like Delta Dave, I’m moving forward. Your patience and understanding is appreciated.
Question: Is there an easy way, within Freeway, to insert special characters (i.e. registered, copyright, trademark, etc.)?
Thank you in advance!
Marc
Hi Marc
You should just be able to insert them using the normal keyboard shortcut or using ® © Keyboard viewer.
Your page should be set to Automatic Encoding but if you are having problems switch to UTF8 - 3rd Tab with nothing selected on the page, near the bottom there is an Encoding type picker.
Dave,
Thanks again.
When I attempted to use another program, you had to select the special character from a drop down and then a sub drop down.
Thank you again for your most generous assistance, and for making my Freeway experience that much better.
Marc
