Possible, sure. It’s quite an engineering project, though.
You’ll want to create some sort of Ajax callback function, where a
JavaScript watches to see when someone has paused in typing for some
defined period of time, then snarfs up all of the text and sends it
back to the server through a back-channel for processing. You’ll
probably end up using the aspell library on the server, and then feed
the result back to the server where your Ajax function will do
something with the result.
If you’re using a normal textarea or text (form field) input, I don’t
think you can do the clever red text with wiggly underline like Word.
But if you use a different type of input, like a DIV in designmode,
then pretty much anything you want to do is possible.
On Mar 13, 2011, at 4:05 PM, sampolfonz wrote:
Is it possible to spell check a form element, as a user is typing in
copy before choosing the Submit button ?
Someone asked me, and I did not know if it was possible.
I just tried a little test document with this, and discovered that
both Safari and Firefox on the Mac offer the dotted red underline “you
spelled badly” coach marks in all form inputs. Also, if you enable
designmode on your document, the same thing holds true for any HTML
text on the page. In Firefox, the coach marks appear the moment you
load the page, in Safari they appear after you click on the word (so I
assume they would also appear as you typed new words).
don’t think you can do the clever red text with wiggly underline
like Word. But if you use a different type of input, like a DIV in
designmode, then pretty much anything you want to do is possible.
