I am glad you posted this, as I spent a few hours trying to grasp the Sprite concept last night, starting with SpriteRight developers page , to CSS Sprites: What They Are, Why They're Cool, and How To Use Them | CSS-Tricks - CSS-Tricks, to Spriteme google projects; http://spriteme.org/
I wasn’t going to, thinking it was to complicated a question and I havn’t really delved into the forum pages yet, but after sleeping on it, I invite responses at your leisure, no pressing issues…
On my page (largely dormant and experimental) http://www.class-e-ads.com/listings.html
the sprite me plugin generates the 2 logos of ebay and craigslist all three horizintaly together. Is it just the plugin trying to help or can this spriteme generated image really be use repetitively as a sprite in that design, downloaded requested/once - if I get the notion…
I bought SpriteRight before my favorite web gurus could respond about the compatibility with Freeway, and in fact before I had a notion of what a sprite is… It has since been upgraded.
I wonder if the ‘stylesheet compatibility’ of either of these two programs are below the code writter level yet?
Thanks, have a great day!
Frank H.
On Mar 15, 2012, at 8:32 AM, bateristt wrote:
Sprite Master Web 1.1 just appeared on the Mac App Store. This is a huge update and has lots of new features like CSS-preview on the fly, PNG image optimizations, CSS minifying, CSS State support and more. All of them listed below:
- Image optimization for PNG. Now, your published spritesheets are optimized.
- Sprite Master Web now tracks file changes on the system and automatically update your sprites.
- Special CSS State code generation depending on your sprite name. for example if your sprite name ends with hover, visited, etc. Sprite Master Web will generate appropriate CSS state code.
- Added mouse and keyboard sprite ordering. You can use your mouse and arrow keys to order your sprites (tip: use CMD+arrow to move faster).
- Added Drag & Drop support.
- Added preferences to change options.
- Added Context Menu. You can update your sprites, reveal them in finder and remove from context menu quickly.
- Ability to minify exported CSS, 3 options (None, standart and high)
- CSS Preview window. Now you can view your CSS and copy your CSS code.
- Background pattern can be changed from preferences.
- Small bug-fixes.
To see more details please visit the iTunes Store at http://itunes.apple.com/us/app/sprite-master-web/id496684718
