I love freeway, however. The one problem I cannot find a solution for is how to edit the menus of the website in one file and then embed that menu appropriately on every page.
The only fix I have discovered so far is to make a page with just a menu and then use iframes to display it on every page. This solution is only a band-aid as I build sites for clients and allow them to make changes with pagelime cms. That way they don’t need to update every pages menus individually. Any input is greatly appreciated! Thanks!
I am not sure if this is the correct answer to your question, but if I understand it, yes.
Make the Menu in question on a page along with all the other elements you will have repeating throughout the pages. Under the ‘Page’ menu scroll to “Make Master”. Anything you wish to be different on subsequent pages you may change on those pages then and there.
Frank H.
I am not familiar with Pagelime but what most FW CMS users do is create a Master with its standard menu and then the rest of the page construction uses an inline layout to accommodate pages that expand with growing CMS content.
